A qualitative mathematical analysis of a class of variational inequalities via semi-complementarity problems. Applications in electronics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
The main object of this paper is to present a general mathematical theory applicable to the study of a large class of variational inequalities arising in electronics.
RR-5990.pdf (560.41 Ko) Télécharger le fichier
inria-00103328 , version 1 (04-10-2006)
inria-00103328 , version 2 (04-10-2006)
  • HAL Id : inria-00103328 , version 2
Khalid Addi, Bernard Brogliato, Daniel Goeleven. A qualitative mathematical analysis of a class of variational inequalities via semi-complementarity problems. Applications in electronics. [Research Report] RR-5990, INRIA. 2006. ⟨inria-00103328v2⟩
292 Consultations
143 Téléchargements
