The CL-Atse Protocol Analyser - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We present a symbolic analysis of the ephemerizer's protocol by Radia Perlman, using the CL-Atse tool from the AVISPA's toolsuite. This protocol allows transmitting a data that will ``disappear'' (i.e. cannot be retrieved) after a certain time. We show that this protocol is secured for this property plus the secrecy of the data, but is trivially non secured for it's integrity. Therefore, we present two extensions of this protocol, one natural and probably already done in practice, the other one much less obvious. We shows that while the first extension guaranty the basic integrity property under certain conditions, the second one is much stronger and even allows faster computations.
RTA06_16_Turuani.pdf (106.62 Ko) Télécharger le fichier
inria-00103573 , version 1 (04-10-2006)
  • HAL Id : inria-00103573 , version 1
Mathieu Turuani. The CL-Atse Protocol Analyser. 17th International Conference on Term Rewriting and Applications - RTA 2006, Aug 2006, Seattle, WA/USA, pp.277--286. ⟨inria-00103573⟩
141 Consultations
924 Téléchargements
