Improving the Courtesy Amount Recognition Accuracy Rate Through Delimiters Identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Eduardo F. A. Silva
  • Fonction : Auteur
  • PersonId : 835715
Rodrigo C. Dória
  • Fonction : Auteur
  • PersonId : 835717
Juliano C. B. Rabelo
  • Fonction : Auteur
  • PersonId : 835718
This paper deals with automatic recognition of real bank checks. A new approach is proposed to read the numerical amount field from bank checks, considering the numeric value and the different delimiters existent in that field. The proposal combines different neural networks classifiers to perform the recognition. Experimental results have shown that this approach is robust and efficient for automatic recognition of real Brazilian bank checks.
cr1054230582975.pdf (460.44 Ko) Télécharger le fichier
inria-00104228 , version 1 (06-10-2006)
  • HAL Id : inria-00104228 , version 1
Cleber Zanchettin, George D. C. Cavalcanti, Eduardo F. A. Silva, Byron L. D. Bezerra, Rodrigo C. Dória, et al.. Improving the Courtesy Amount Recognition Accuracy Rate Through Delimiters Identification. Tenth International Workshop on Frontiers in Handwriting Recognition, Université de Rennes 1, Oct 2006, La Baule (France). ⟨inria-00104228⟩
Collections
IWFHR10
23 Consultations
200 Téléchargements
