Periodic Global Parameterization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2006
Nicolas Ray
Wan Chiu Li
  • Fonction : Auteur
  • PersonId : 835816
Bruno Lévy
Alla Sheffer
  • Fonction : Auteur
Pierre Alliez
We present a new globally smooth parameterization method for triangulated surfaces of arbitrary topology. Given two orthogonal piecewise linear vector fields defined over the input mesh (typically the estimated principal curvature directions), our method computes two piecewise linear periodic functions, aligned with the input vector fields, by minimizing an objective function. The bivariate function they define is a smooth parameterization almost everywhere on the surface, except in the vicinity of singular vertices, edges and triangles, where the derivatives of the parameterization vanish. We extract a quadrilateral chart layout from the parameterization function and propose an automatic procedure to detect the singularities, and fix them by splitting and re-parameterizing the containing charts. Our method can construct both quasi-conformal (angle preserving) and quasi-isometric (angle and area preserving) parameterizations. The more restrictive class of quasi-isometric parameterizations is constructed at the expense of introducing more singularities. The constructed parameterizations can be used for a variety of geometry processing applications. Since we can align the parameterization with the principal curvature directions, our result is particularly suitable for surface fitting and remeshing.
pgp.pdf (3 Mo) Télécharger le fichier
inria-00104853 , version 1 (11-10-2006)
Nicolas Ray, Wan Chiu Li, Bruno Lévy, Alla Sheffer, Pierre Alliez. Periodic Global Parameterization. ACM Transactions on Graphics, 2006, ⟨10.1145/1183287.1183297⟩. ⟨inria-00104853⟩
1072 Consultations
857 Téléchargements
