Definitions by Rewriting in the Calculus of Constructions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
The main novelty of this paper is to consider an extension of the Calculus of Constructions where predicates can be defined with a general form of rewrite rules. We prove the strong normalization of the reduction relation generated by the beta-rule and the user-defined rules under some general syntactic conditions including confluence. As examples, we show that two important systems satisfy these conditions: a sub-system of the Calculus of Inductive Constructions which is the basis of the proof assistant Coq, and the Natural Deduction Modulo a large class of equational theories.
main.pdf (218.2 Ko) Télécharger le fichier
inria-00105568 , version 1 (11-10-2006)
Frédéric Blanqui. Definitions by Rewriting in the Calculus of Constructions. 16th Annual IEEE Symposium on Logic in Computer Science, Jun 2001, Boston, United States. ⟨inria-00105568⟩
87 Consultations
114 Téléchargements
