Mesh Editing with an Embedded Network of Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We propose a method for uncalibrated stereo matching. The method applies gradual elastic deformation to the line segments in a pair of images until they match with each other. By using an energy function and a neighborhood function, matching is performed in a coarse-to-fine manner. Our method gives point correspondences with a low proportion of outliers and is robust in the uncalibrated case (with no need to estimate the epipolar geometry). The computation complexity is proportional to the square of the number of line segments in the images, which is relatively efficient compared with other elaborate methods.
mesh_cutting.pdf (3.45 Mo) Télécharger le fichier
inria-00105658 , version 1 (11-10-2006)
Bruno Lévy, Wan Chiu Li, Jean-Claude Paul. Mesh Editing with an Embedded Network of Curves. IEEE International Conference on Shape Modeling and Applications - SMI 2005, Jun 2005, Cambridge, USA, pp.62-71, ⟨10.1109/SMI.2005.29⟩. ⟨inria-00105658⟩
268 Consultations
366 Téléchargements
