Querying and Updating Probabilistic Information in XML - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We present in this paper a new model for representing probabilistic information in a semi-structured (XML) database, based on the use of probabilistic event variables. This work is motivated by the need of keeping track of both confidence and lineage of the information stored in a semi-structured warehouse. For instance, the modules of a (Hidden Web) content warehouse may derive information concerning the semantics of discovered Web services that is by nature not certain. Our model, namely the fuzzy tree model, supports both querying (tree pattern queries with join) and updating (transactions containing an arbitrary set of insertions and deletions) over probabilistic tree data. We highlight its expressive power and discuss implementation issues.
abiteboul2006querying-short.pdf (358.9 Ko) Télécharger le fichier
abiteboul2006querying-short_slides.pdf (554.64 Ko) Télécharger le fichier
Format : Autre
inria-00106788 , version 1 (16-10-2006)
  • HAL Id : inria-00106788 , version 1
Serge Abiteboul, Pierre Senellart. Querying and Updating Probabilistic Information in XML. Extending DataBase Technology, Mar 2006, Munich/Allemagne. ⟨inria-00106788⟩
84 Consultations
169 Téléchargements
