Intrusion detection mechanisms for VoIP applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
VoIP applications are emerging today as an important component in business and communication industry. In this paper, we address the intrusion detection and prevention in VoIP networks and describe how a conceptual solution based on the Bayes inference approach can be used to reinforce the existent security mechanisms. Our approach is based on network monitoring and analyzing of the VoIP-specific traffic. We give a detailed example on attack detection using the SIP signaling protocol.
paper1.pdf (278.79 Ko) Télécharger le fichier
inria-00107054 , version 1 (18-10-2006)
Mohamed Nassar, Radu State, Olivier Festor. Intrusion detection mechanisms for VoIP applications. Third annual VoIP security workshop - VSW'06, Fraunhofer FOKUS, Jun 2006, Berlin/Allemagne, Germany. ⟨inria-00107054⟩
158 Consultations
411 Téléchargements
