Optical Filtering for Near Field Photometry with High Order Basis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Accurately capturing the near field emission of complex luminaires is still very difficult. In this paper, we describe a new acquisition pipeline of such luminaires that performs an orthogonal projection on a given basis in a two-step procedure. First, we use an optical low-pass filter that corresponds to the reconstruction basis to guarantee high precision measurements. The second step is a numerical process on the acquired data that finalizes the projection. Based on this concept, we introduce new experimental setups for automatic acquisition and perform a detailed error analysis of the acquisition process.
RR-6000.pdf (1.91 Mo) Télécharger le fichier
inria-00107463 , version 1 (18-10-2006)
inria-00107463 , version 2 (23-10-2006)
  • HAL Id : inria-00107463 , version 2
Xavier Granier, Michael Goesele, Wolfgang Heidrich, Hans-Peter Seidel. Optical Filtering for Near Field Photometry with High Order Basis. [Research Report] RR-6000, INRIA. 2006. ⟨inria-00107463v2⟩
172 Consultations
113 Téléchargements
