s'authentifier
version française rss feed
!.. Document complet sous embargo ..!
Mise en ligne du document : document non public
inria-00107600, version 1
SBM protocol for providing real-time QoS in Ethernet LANs
Anis Koubaa () a1, Aref Jarraya 1, Ye-Qiong Song b1
1st International Workshop on Real-Time LANs in the Internet Age - RTLIA'2002 (2002) 45-49
Résumé : This paper deals with the performance evaluation of LAN-Integrated Service protocol called SBM (Subnetwork Bandwidth Manager), a solution to handle QoS requirements over Local Area Networks. SBM is an RSVP-based protocol, which consists in electing a manager over a LAN segment to map RSVP-flows into an appropriate class of service and handles admission control and bandwidth reservation operations for such flows. To show how SBM is useful for guaranteeing requested quality of service for real-time admitted flows, we simulated the bandwidth reservation and message scheduling in an Ethernet switch for different input flows sharing a same output trunk link. DSBM election has also been simulated in order to evaluate time for DSBM failure recovery over switched and shared LAN topology.
  • a –  INPL
  • b –  INRIA
  • 1 :  TRIO (INRIA Lorraine - LORIA)
  • INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
  • Domaine : Informatique/Autre
  • Mots-clés : subnet bandwidth manager – quality of service – simulation – dsbm election protocol – performance evaluation || subnet bandwidth manager – qualité de service – protocole d'élection du dsbm – évaluation de performance
  • Référence interne : A02-R-349 || koubaa02e
  • Commentaire : Colloque avec actes et comité de lecture. internationale.
  • inria-00107600, version 1
  • oai:hal.inria.fr:inria-00107600
  • Contributeur :
  • Soumis le : Jeudi 19 Octobre 2006, 09:02:46
  • Dernière modification le : Vendredi 1 Juin 2007, 11:32:04
tous les articles de la base du CCSd...
