Performance Implications by the Hierarchical Design of Clusters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Mohamed Essaïdi
  • Fonction : Auteur
  • PersonId : 835367
Jens Gustedt
We present experimental results for the evaluation of PC clusters that differ on several aspect of their architecture, such as being mono or biprocessors and having a high bandwidth interconnection network or not. These experiments confirm that a good equilibrium between the speed (throughput) of the different components is crucial for a satisfactory performance of such a machine. On the other hand they also show that the latency of the underlying infrastructure is of less importance and can be hidden by applying techniques from coarse grained parallelism.
A03-R-142.pdf (86.31 Ko) Télécharger le fichier
inria-00107662 , version 1 (15-01-2007)
  • HAL Id : inria-00107662 , version 1
Wissem Ben Fraj, Mohamed Essaïdi, Jens Gustedt. Performance Implications by the Hierarchical Design of Clusters. The 7th world multiconference on Systemics, Cybernetics and Informatics - SCI'2003, Jul 2003, Orlando, USA, 6 p. ⟨inria-00107662⟩
1036 Consultations
421 Téléchargements
