s'authentifier
version française rss feed
!.. Document complet sous embargo ..!
Mise en ligne du document : document non public
inria-00107876, version 1
Matching Power
Horatiu Cirstea () a1, Claude Kirchner b1, Luigi Liquori b2
12th International Conference on Rewriting Techniques and Applications - RTA'2001 (2001) 18 p
Résumé : In this paper we give a simple and uniform presentation of the rewriting calculus, also called Rho-Calculus. In addition to its simplicity, this formulation explicitly allows us to encode complex structures such as lists, sets, and objects. We provide extensive examples of the calculus, and we focus on its ability to represent some object oriented calculi, namely the Lambda Calculus of Objects of Fisher, Honsell, and Mitchell, and the Object Calculus of Abadi and Cardelli. Furthermore, the calculus allows us to get object oriented constructions unreachable in other calculi. In summa, we intend to show that because of its matching ability, the Rho-Calculus represents a lingua franca to naturally encode many paradigms of computations. This enlightens the capabilities of the rewriting calculus based language ELAN to be used as a logical as well as powerful semantical framework.
  • a –  INPL
  • b –  INRIA
  • 1 :  PROTHEO (INRIA Lorraine - LORIA)
  • INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
  • 2 :  MIRHO (INRIA SOPHIA ANTIPOLIS / INRIA LORRAINE - LORIA)
  • CNRS : UMR7503 – INRIA – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
  • Domaine : Informatique/Autre
  • Mots-clés : matching – rewriting calculus – object oriented calculi || filtrage – calcul de réécriture – calculs orientés objet
  • Référence interne : A01-R-201 || cirstea01b
  • Commentaire : Colloque avec actes et comité de lecture. internationale.
  • inria-00107876, version 1
  • oai:hal.inria.fr:inria-00107876
  • Contributeur :
  • Soumis le : Jeudi 19 Octobre 2006, 09:12:44
  • Dernière modification le : Vendredi 20 Octobre 2006, 15:32:31
tous les articles de la base du CCSd...
