s'authentifier
version française rss feed
inria-00108307, version 1
HMM-Based On-Line Recognition of Handwritten Whiteboard Notes
Marcus Liwicki () 1, Horst Bunke () 1
Tenth International Workshop on Frontiers in Handwriting Recognition (2006)
Résumé : In this paper we present an on-line recognition system for handwritten texts acquired from a whiteboard. This input modality has received relatively little attention in the handwriting recognition community in the past. The system proposed in this paper uses state-of-the-art normalization and feature extraction strategies to transform a handwritten text line into a sequence of feature vectors. Additional preprocessing techniques are introduced, which significantly increase the word recognition rate. For classification, Hidden Markov Models are used together with a statistical language model. In writer independent experiments we achieved word recognition rates of 67.3% on the test set when no language model is used, and 70.8% by including a language model.
  • Domaine : Informatique/Traitement du texte et du document
    Informatique/Vision par ordinateur et reconnaissance de formes
  • Mots-clés : Handwritten Text Recognition – HMM – On-line – Writer-Independend
  • Commentaire : http://www.suvisoft.com
  • inria-00108307, version 1
  • oai:hal.inria.fr:inria-00108307
  • Contributeur :
  • Soumis le : Vendredi 20 Octobre 2006, 13:35:57
  • Dernière modification le : Vendredi 20 Octobre 2006, 13:37:18
tous les articles de la base du CCSd...
