s'authentifier
version française rss feed
inria-00108401, version 1
Combination of Multiple Handwritten Text Line Recognition Systems with a Recursive Approach
Roman Bertolami () 1, Beat Halter () 1, Horst Bunke () 1
Tenth International Workshop on Frontiers in Handwriting Recognition (2006)
Résumé : In this paper we propose a novel method to combine the results of multiple text line recognition systems. The method uses a recursive approach and re-examines those parts in a text line which have been rejected based on the initial combination of the base recognisers' results. By means of the new method, the search space can be reduced, and therefore more accurate recognition results can be expected. Experiments conducted on the IAM database show that the proposed method is able to improve the recognition rate compared to a standard combination scheme.
  • Domaine : Informatique/Traitement du texte et du document
    Informatique/Vision par ordinateur et reconnaissance de formes
  • Mots-clés : Handwritten Text Line Recognition – Multiple Classifier Systems – Hidden Markov Models
  • Commentaire : http://www.suvisoft.com
  • inria-00108401, version 1
  • oai:hal.inria.fr:inria-00108401
  • Contributeur :
  • Soumis le : Vendredi 20 Octobre 2006, 16:12:12
  • Dernière modification le : Vendredi 20 Octobre 2006, 16:23:02
tous les articles de la base du CCSd...
