Handling Conflicts through Multi-level Editing in Peer-to-peer Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The handling of conflicts in collaborative editing over hierarchical documents in peer-to-peer networks is a very important issue. In this paper we show how the multi-level editing approach that recursively applies a tombstone transformational approach over the document levels offers support for flexible conflict definition and resolution.
IgnatCEW06.pdf (49.78 Ko) Télécharger le fichier
inria-00109098 , version 1 (02-04-2007)
  • HAL Id : inria-00109098 , version 1
Claudia Lavinia Ignat, Moira Norrie, Gérald Oster. Handling Conflicts through Multi-level Editing in Peer-to-peer Environments. International Workshop on Collaborative Editing Systems - CEW 2006, Nov 2006, Banff, Alberta, Canada. ⟨inria-00109098⟩
112 Consultations
145 Téléchargements
