Analysis and Low-order Modeling of the Three-dimensional Flow Past a Confined Square Cylinder
The laminar flow past a square cylinder symmetrically placed between two parallel walls is considered. A classical vortex wake is shed from the cylinder, but three-dimensional instabilities are present and they develop in complicated flow patterns. The possibility of extracting an accurate low-order model of this flow is explored.
Modélisation et simulation
