Instantiation of relations for semantic annotation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents a methodology for the semantic annotation of web pages with individuals of a domain ontology. While most semantic annotation systems can recognize knowledge units, they usually do not establish explicit relations between them. The method presented identifies the individuals which should be related among the whole set of individuals and codes them as role instances within an OWL ontology. This is done by using a correspondence between the tree structure of a web page and the semantics of the information it contains.
stenier-relations.pdf (352.65 Ko) Télécharger le fichier
inria-00110515 , version 1 (30-10-2006)
  • HAL Id : inria-00110515 , version 1
Sylvain Tenier, Yannick Toussaint, Amedeo Napoli, Xavier Polanco. Instantiation of relations for semantic annotation. The 2006 IEEE/WIC/ACM International Conference on Web Intelligence - WI 2006, Hong Kong Baptist University, Dec 2006, Hong Kong, China. pp.463-472. ⟨inria-00110515⟩
209 Consultations
386 Téléchargements
