Closed-loop fault-tolerant control for uncertain nonlinear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We are designing, perhaps for the first time, closed-loop fault-tolerant control for uncertain nonlinear systems. Our solution is based on a new algebraic estimation technique of the derivatives of a time signal, which • yields good estimates of the unknown parameters and of the residuals, i.e., of the fault indicators, • is easily implementable in real time, • is robust with respect to a large variety of noises, without any necessity of knowing their statistical properties. Convincing numerical simulations are provided via a popular case-study in the diagnosis community, namely the three-tank system, which may be characterized as a flat hybrid system.
Zeitz_finale.pdf (1.67 Mo) Télécharger le fichier
inria-00111208 , version 1 (04-11-2006)
  • HAL Id : inria-00111208 , version 1
Michel Fliess, Cédric Join, Hebertt Sira-Ramirez. Closed-loop fault-tolerant control for uncertain nonlinear systems. Control and Observer Design for Nonlinear Finite and Infinite Dimensional Systems, Sep 2005, Stuttgart, Germany. pp.217-233. ⟨inria-00111208⟩
316 Consultations
489 Téléchargements
