inria-00112648, version 1
A Block-Based Hough Transform Mapping for Text Line Detection in Handwritten Documents
G. Louloudis
1B. Gatos
2I. Pratikakis
2K. Halatsis
1
Tenth International Workshop on Frontiers in Handwriting Recognition (2006)
Résumé : In this paper, we present a new text line detection method for unconstrained handwritten documents. The proposed technique is based on a strategy that consists of three distinct steps. The first step includes preprocessing for image enhancement, connected component extraction and average character height estimation. In the second step, a block-based Hough transform is used for the detection of potential text lines while a third step is used to correct possible false alarms. The performance of the proposed methodology is based on a consistent and concrete evaluation technique that relies on the comparison between the text line detection result and the corresponding ground truth annotation.
- 1 : Department of Informatics and Telecommunications (Athens)
- National and Kapodistrian University of Athens
- 2 : Computational Intelligence Laboratory [Athens] (CIL)
- Institute of Informatics and Telecommunications – National Center for Scienfic Research Demokritos
- Domaine : Informatique/Traitement du texte et du document
Informatique/Vision par ordinateur et reconnaissance de formes - Mots-clés : Document Analysis – Unconstrained Handwriting – Hough Transform – Text Line Detection – Connected Component Analysis
- Commentaire : http://www.suvisoft.com
- inria-00112648, version 1
- http://hal.inria.fr/inria-00112648
- oai:hal.inria.fr:inria-00112648
- Contributeur : Anne Jaigu
- Soumis le : Jeudi 9 Novembre 2006, 14:24:27
- Dernière modification le : Jeudi 9 Novembre 2006, 16:47:55
Documents associés
Exporter
