A Machine Learning approach for Statistical Software Testing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Some Statistical Software Testing approaches rely on sampling the feasible paths in the control flow graph of the program; the difficulty comes from the tiny ratio of feasible paths. This paper presents an adaptive sampling mechanism called EXIST for Exploration/eXploitation Inference for Software Testing, able to retrieve distinct feasible paths with high probability. EXIST proceeds by alternatively exploiting and updating a distribution on the set of program paths. An original representation of paths, accommodating long-range dependencies and data sparsity and based on extended Parikh maps, is proposed. Experimental validation on real-world and artificial problems demonstrates dramatic improvements compared to the state of the art.
existIJ07.pdf (184.1 Ko) Télécharger le fichier
inria-00112681 , version 1 (09-11-2006)
  • HAL Id : inria-00112681 , version 1
Nicolas Baskiotis, Michèle Sebag, Marie-Claude Gaudel, Sandrine-Dominique Gouraud. A Machine Learning approach for Statistical Software Testing. Twentieth International Joint Conference on Artificial Intelligence, Jan 2007, Hyderabad, India. ⟨inria-00112681⟩
183 Consultations
285 Téléchargements
