Learning for stochastic dynamic programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Sylvain Gelly
  • Fonction : Auteur
  • PersonId : 836546
Jérémie Mary
Olivier Teytaud
We present experimental results about learning function values (i.e. Bellman values) in stochastic dynamic programming (SDP). All results come from openDP (opendp.sourceforge.net), a freely available source code, and therefore can be reproduced. The goal is an independent comparison of learning methods in the framework of SDP.
lfordp.pdf (99.33 Ko) Télécharger le fichier
inria-00112796 , version 1 (09-11-2006)
  • HAL Id : inria-00112796 , version 1
Sylvain Gelly, Jérémie Mary, Olivier Teytaud. Learning for stochastic dynamic programming. 11th European Symposium on Artificial Neural Networks (ESANN), Apr 2006, bruges Belgium. ⟨inria-00112796⟩
253 Consultations
322 Téléchargements
