Bayesian Networks: a Non-Frequentist Approach for Parametrization, and a more Accurate Structural Complexity Measure - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue des Sciences et Technologies de l'Information - Série RIA : Revue d'Intelligence Artificielle Année : 2006
Sylvain Gelly
  • Fonction : Auteur
  • PersonId : 836546
Olivier Teytaud
The problem of calibrating relations from examples is a classical problem in learning theory. This problem has in particular been studied in the theory of empirical processes (providing asymptotic results), and through statistical learning theory. The application of learning theory to bayesian networks is still uncomplete and we propose a contribution, especially through the use of covering numbers. We deduce multiple corollaries, among which a non-frequentist approach for parameters learning and a score taking into account a measure of structural entropy that has never been taken into account before. We then investigate the algorithmic aspects of our theoretical solution, based on BFGS and adaptive refining of gradient calculus. Empirical results show the relevance of both the statistical results and the algorithmic solution.
BN_RIA.pdf (671.05 Ko) Télécharger le fichier
inria-00112838 , version 1 (09-11-2006)
  • HAL Id : inria-00112838 , version 1
Sylvain Gelly, Olivier Teytaud. Bayesian Networks: a Non-Frequentist Approach for Parametrization, and a more Accurate Structural Complexity Measure. Revue des Sciences et Technologies de l'Information - Série RIA : Revue d'Intelligence Artificielle, 2006. ⟨inria-00112838⟩
163 Consultations
145 Téléchargements
