Exploring the Gap between Linear and Classical Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theory and Applications of Categories Année : 2007
The Medial rule was first devised as a deduction rule in the Calculus of Structures. In this paper we explore it from the point of view of category theory, as additional structure on a *-autonomous category. This gives us some insights on the denotational semantics of classical propositional logic, and allows us to construct new models for it, based on suitable generalizations of the theory of coherence spaces.
GapTac.pdf (485.29 Ko) Télécharger le fichier
inria-00113785 , version 1 (14-11-2007)
  • HAL Id : inria-00113785 , version 1
François Lamarche. Exploring the Gap between Linear and Classical Logic. Theory and Applications of Categories, 2007, 18 (17), 473--535 (63 p.). ⟨inria-00113785⟩
148 Consultations
196 Téléchargements
