Impact of a (m,k)-firm Data Dropouts Policy on the Quality of Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Flavia Felicioni
  • Fonction : Auteur
  • PersonId : 836665
Ning Jia
  • Fonction : Auteur
  • PersonId : 831004
Ye-Qiong Song
In this paper, we propose a method for the design of an operational architecture of a Networked Control System (NCS). We consider a control system whose main goal is to control the position of a cart moving along a rail. The implementation of the controller is done through a distributed architecture in which a shared network supports the transmission of the samples between the sensor and the controller. For efficiently handling network congestion, we propose to apply a selective sample drop policy according to a (m,k)-pattern in order to decrease the network bandwidth required by this application during network overload periods. The paper shows how to determine the values of the parameter k that preserve the stability of the system and then how to identify the value of m and the (m,k)-pattern in order to optimize the system performance.
WFCS06-submit-FF-NJ-YQS-FSL-Finalversion.pdf (469.52 Ko) Télécharger le fichier
inria-00113827 , version 1 (14-11-2006)
  • HAL Id : inria-00113827 , version 1
Flavia Felicioni, Ning Jia, Ye-Qiong Song, Françoise Simonot-Lion. Impact of a (m,k)-firm Data Dropouts Policy on the Quality of Control. 6th IEEE International Workshop on Factory Communication Systems, Jun 2006, Torino, Italy, pp.353-359. ⟨inria-00113827⟩
219 Consultations
209 Téléchargements
