inria-00116651, version 3
Reconstruction with Voronoi Centered Radial Basis Functions
Marie Samozino
1Marc Alexa a, 2Pierre Alliez
1Mariette Yvinec
1
N° RR-6033 (2006)
Résumé : We consider the problem of reconstructing a surface from scattered points sampled on a physical shape. The sampled shape is approximated as the zero level set of a function. This function is defined as a linear combination of compactly supported radial basis functions. We depart from previous work by using as centers of basis functions a set of points located on an estimate of the medial axis, instead of the input data points. Those centers are selected among the vertices of the Voronoi diagram of the sample data points. Being a Voronoi vertex, each center is associated with a maximal empty ball. We use the radius of this ball to adapt the support of each radial basis function. Our method can fit a user-defined budget of centers: The selected subset of Voronoi vertices is filtered using the notion of lambda medial axis, then clustered to fit the allocated budget.
- a – TU Braunschweig
- 1 : GEOMETRICA (INRIA Sophia Antipolis)
- INRIA
- 2 : Technische Universität Berlin (TUB)
- Technische Universität Berlin
- Domaine : Informatique/Géométrie algorithmique
- Mots-clés : Computer Graphics – Surface Reconstruction from Scattered Data – Radial Basis Functions – implicit function.
- Référence interne : RR-6033
- Commentaire : The dinosaur model is courtesy of Cyberware – other models being courtesy of the AIM@SHAPE shape repository
- Versions disponibles : v1 (27-11-2006) v2 (27-11-2006) v3 (28-11-2006)
- inria-00116651, version 3
- http://hal.inria.fr/inria-00116651
- oai:hal.inria.fr:inria-00116651
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mardi 28 Novembre 2006, 11:38:29
- Dernière modification le : Mercredi 1 Octobre 2008, 11:36:26
Documents associés
Exporter
