A Case Study of the Convergence of Mildly Context-Sensitive Formalisms for Natural Language Syntax: from Minimalist Grammars to Multiple Context-Free Grammars - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
The present work is set in the field of natural language syntactic parsing. We present the concept of "mildly context-sensitive" grammar formalisms, which are full-fetched and efficient for syntactic parsing. We summarize a number of these formalisms' definitions, together with the relations between one another, and, most importantly, a survey of known equivalences. The conversion of Edward Stabler's Minimalist Grammars into Multiple Context-Free Grammars (MCFG) is presented in particular detail, along with a study of the complexity of this procedure and of its implications for parsing. This report is an adaptation of the French Master thesis that bears the same name, from Bordeaux 1 University, June 2006.
RR_6042.pdf (394.75 Ko) Télécharger le fichier
inria-00117306 , version 1 (01-12-2006)
inria-00117306 , version 2 (04-12-2006)
inria-00117306 , version 3 (04-12-2006)
  • HAL Id : inria-00117306 , version 3
Bruno Mery, Maxime Amblard, Irène Durand, Christian Retoré. A Case Study of the Convergence of Mildly Context-Sensitive Formalisms for Natural Language Syntax: from Minimalist Grammars to Multiple Context-Free Grammars. [Research Report] RR-6042, INRIA. 2006, pp.67. ⟨inria-00117306v3⟩
266 Consultations
375 Téléchargements
