ESTIMATION OF MINIMUM MEASURE SETS IN REPRODUCING KERNEL HILBERT SPACES AND APPLICATIONS. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Minimum measure sets (MMSs) summarize the information of a (single-class) dataset. In many situations, they can be preferred to estimated probability density functions (pdfs): they are strongly related to pdf level sets while being much easier to estimate in large dimensions. The main contribution of this paper is a theoretical connection between MMSs and one class Support Vector Machines. This justifies the use of one-class SVMs in the following applications: novelty detection (we give explicit convergence rate) and change detection.
Desobry_ICASSP_2006.pdf (189.56 Ko) Télécharger le fichier
inria-00119999 , version 1 (12-12-2006)
  • HAL Id : inria-00119999 , version 1
Manuel Davy, Frederic Desobry, Stephane Canu. ESTIMATION OF MINIMUM MEASURE SETS IN REPRODUCING KERNEL HILBERT SPACES AND APPLICATIONS.. IEEE ICASSP 2006, 2006, Toulouse, France. ⟨inria-00119999⟩
121 Consultations
252 Téléchargements
