Evolutionary Robotics, Anticipation and the Reality Gap - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Evolutionary Robotics provide efficient tools and approach to address automatic design of controllers for automous mobile robots. However, the computational cost of the optimization process makes it difficult to evolve controllers directly into the real world. This paper addresses the key problem of tranferring into the real world a robotic controller that has been evolved in a robotic simulator. The approach presented here relies on the definition of an anticipation-enabled control architecture. The anticipation module is able to build a partial model of the simulated environment and, once in the real world, performs an error estimation of this model. This error can be reused so as to perform in-situ on-line adaptation of robot control. Experiments in simulation and real-world showed that an evolved robot is able to perform on-line recovery from several kind of locomotion perturbations
robios2006.pdf (470.46 Ko) Télécharger le fichier
inria-00120116 , version 1 (13-12-2006)
  • HAL Id : inria-00120116 , version 1
Cedric Hartland, Nicolas Bredeche. Evolutionary Robotics, Anticipation and the Reality Gap. ROBIO 2006, Dec 2006, Kunming/Chine, China. pp.1640-1645. ⟨inria-00120116⟩
186 Consultations
181 Téléchargements
