Error Bounds on Complex Floating-Point Multiplication
Given floating-point arithmetic with $t$-digit base-$\beta$ significands in which all arithmetic operations are performed as if calculated to infinite precision and rounded to a nearest representable value, we prove that the product of complex values $z_0$ and $z_1$ can be computed with maximum absolute error $\abs{z_0} \abs{z_1} \frac{1}{2} \beta^{1 - t} \sqrt{5}$. In particular, this provides relative error bounds of $2^{-24} \sqrt{5}$ and $2^{-53} \sqrt{5}$ for {IEEE 754} single and double precision arithmetic respectively, provided that overflow, underflow, and denormals do not occur. We also provide the numerical worst cases for {IEEE 754} single and double precision arithmetic.
