s'authentifier
version française rss feed
inria-00124825, version 2
Normal Cone Approximation and Offset Shape Isotopy
Frédéric Chazal () 1, David Cohen-Steiner () 1, André Lieutier () a2
N° RR-6100 (2007)
Résumé : This work adresses the problem of the approximation of the normals of the offsets of general compact sets in euclidean spaces. It is proven that for general sampling conditions, it is possible to approximate the gradient vector field of the distance to general compact sets. These conditions involve the $\mu$-reach of the compact set, a recently introduced notion of feature size. As a consequence, we provide a sampling condition that is sufficient to ensure the correctness up to isotopy of a reconstruction given by an offset of the sampling. We also provide a notion of normal cone to general compact sets which is stable under perturbation.
  • Domaine : Informatique/Géométrie algorithmique
  • Mots-clés : Distance Function – Medial Axis – geometric approximation – normal cone
  • Référence interne : RR-6100
  • Versions disponibles :  v1 (16-01-2007) v2 (20-01-2007)
  • inria-00124825, version 2
  • oai:hal.inria.fr:inria-00124825
  • Contributeur :
  • Soumis le : Samedi 20 Janvier 2007, 10:18:04
  • Dernière modification le : Jeudi 2 Octobre 2008, 15:27:59
tous les articles de la base du CCSd...
