inria-00125475, version 1
VXT: A Visual Approach to XML Transformations
Emmanuel Pietriga
a, 1, 2Jean-Yves Vion-Dury a, 2Vincent Quint
b, 1, 3
ACM Symposium on Document Engineering (2001)
Résumé : The domain of XML transformations is becoming more and more important as a result of the increasing number of applications adopt- ing XML as their format for data exchange or representation. Most of the existing solutions for expressing XML transformations are textual languages, such as XSLT or DOM combined with a general- purpose programming language. Several tools build on top of these languages, providing a graphical environment. Transformations are however still specified in a textual way using the underlying lan- guage (often XSLT), thus requiring the user to learn the associated textual language. We believe that visual programming techniques are well-suited to representing XML structures and make the specification of trans- formations simpler. We present a visual programming language for the specification of XML transformations in an interactive environ- ment, based on a zoomable user interface toolkit. Transformations can be run from the application or exported to two target languages: XSLT and Circus, a general-purpose structure transformation lan- guage designed by the second author and briefly introduced in this paper.
- a – Xerox
- b – INRIA
- 1 : OPERA (INRIA Rhône-Alpes)
- INRIA
- 2 : Xerox Research Centre Europe (XRCE)
- Xerox
- 3 : Institut d'Informatique et de Mathématiques Appliquées de Grenoble (IMAG)
- CNRS – Institut National Polytechnique de Grenoble - INPG – Faculté des Sciences de l'Université de Grenoble
- Domaine : Informatique/Interface homme-machine
Informatique/Web
- inria-00125475, version 1
- http://hal.inria.fr/inria-00125475
- oai:hal.inria.fr:inria-00125475
- Contributeur : Emmanuel Pietriga
- Soumis le : Vendredi 19 Janvier 2007, 16:59:19
- Dernière modification le : Mardi 31 Mai 2011, 15:14:43
Documents associés
Exporter
