Simulation of diffusions by means of importance sampling paradigm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2010
The aim of this paper is to introduce a new Monte Carlo method based on importance sampling techniques for the simulation of stochastic differential equations. The main idea is here to combine random walk on squares or rectangles methods with importance sampling techniques. The first interest of this approach is that the weights can be easily computed from the density of the one-dimensional Brownian motion. Compared to the Euler scheme this method allows to obtain a more accurate approximation of diffusions when one has to consider complex boundary conditions. The method provides also an interesting alternative to perform variance reduction techniques and to simulate rare events.
deaconu_lejay_random_walk_rectangles_importance_sampling.pdf (356.44 Ko) Télécharger le fichier
inria-00126339 , version 1 (24-01-2007)
inria-00126339 , version 2 (19-11-2009)
Madalina Deaconu, Antoine Lejay. Simulation of diffusions by means of importance sampling paradigm. The Annals of Applied Probability, 2010, 20 (4), pp.1389-1424. ⟨10.1214/09-AAP659⟩. ⟨inria-00126339v2⟩
196 Consultations
360 Téléchargements
