A Model for Developing Component-Based and Aspect-Oriented Systems
Aspect-Oriented Programming (AOP) and Component-Based Software Engineering (CBSE) offer solutions to improve the separation of concerns and to enhance a program structure. If the integration of AOP into CBSE has already been proposed, none of these solutions focus onthe application of CBSE principles to AOP. In this paper we propose a twofold integration of AOP and CBSE. We introduce a general model for components and aspects, named Fractal Aspect Component (FAC). FAC decomposes a software system into regular components and aspect components (ACs), where an AC is a regular component that embodies a crosscutting concern. We reify the aspect domain of an AC and the relationship between an AC and a component, called an aspect binding, as first-class runtime entities. This clarifies the architecture of a system where components and aspects coexist. The system can evolve from the design to the execution by adding or removing components, aspects or bindings.
Génie logiciel [cs.SE]
