inria-00127356, version 1
NewMadeleine: a Fast Communication Scheduling Engine for High Performance Networks
Olivier Aumage 1, 2Elisabeth Brunet 1, 2Nathalie Furmento
1, 2Raymond Namyst 1, 2
Workshop on Communication Architecture for Clusters (CAC 2007), workshop held in conjunction with IPDPS 2007 (2007)
Résumé : Communication libraries have dramatically made progress over the fifteen years, pushed by the success of cluster architectures as the preferred platform for high performance distributed computing. However, many potential optimizations are left unexplored in the process of mapping application communication requests onto low level network commands. The fundamental cause of this situation is that the design of communication subsystems is mostly focused on reducing the latency by shortening the critical path. In this paper, we present a new communication scheduling engine which dynamically optimizes application requests in accordance with the NICs capabilities and activity. The optimizing code is generic and portable. The database of optimizing strategies may be dynamically extended.
- 1 : RUNTIME (INRIA Futurs)
- INRIA – CNRS : UMR5800 – Université Sciences et Technologies - Bordeaux I – Ecole Nationale Supérieure d'Electronique, Informatique et Radiocommunications de Bordeaux
- 2 : Laboratoire Bordelais de Recherche en Informatique (LaBRI)
- CNRS : UMR5800 – Université Sciences et Technologies - Bordeaux I – Ecole Nationale Supérieure d'Electronique, Informatique et Radiocommunications de Bordeaux – Université Victor Segalen - Bordeaux II
- Domaine : Informatique/Calcul parallèle, distribué et partagé
- inria-00127356, version 1
- http://hal.inria.fr/inria-00127356
- oai:hal.inria.fr:inria-00127356
- Contributeur : Nathalie Furmento
- Soumis le : Lundi 29 Janvier 2007, 14:57:32
- Dernière modification le : Vendredi 20 Février 2009, 11:49:29
Documents associés
Exporter
