What is a logic, and what is a proof ? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2005
I will discuss the two problems of how to define identity between logics and how to define identity between proofs. For the identity of logics, I propose to simply use the notion of preorder equivalence. This might be considered to be folklore, but is exactly what is needed from the viewpoint of the problem of the identity of proofs: If the proofs are considered to be part of the logic, then preorder equivalence becomes equivalence of categories, whose arrows are the proofs. For identifying these, the concept of proof nets is discussed.
WhatLogicProof.pdf (227.48 Ko) Télécharger le fichier
inria-00130523 , version 1 (30-11-2012)
  • HAL Id : inria-00130523 , version 1
Lutz Strassburger. What is a logic, and what is a proof ?. Jean-Yves Beziau. Logica Universalis, Birkhäuser, pp.135-145, 2005, 978-3-7643-7259-0. ⟨inria-00130523⟩
317 Consultations
390 Téléchargements
