Delay identification in time-delay systems using variable structure observers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annual Reviews in Control Année : 2006
In this paper we discuss delay estimation in time-delay systems. In the introduction section a short overview is given of some existing estimation techniques as well as identifiability studies. In the following sections we propose several algorithms for the delay identification based on variable structure observers.
delay-observers.pdf (554.53 Ko) Télécharger le fichier
inria-00131003 , version 1 (25-11-2007)
Serguey Drakunov, Wilfrid Perruquetti, Jean-Pierre Richard, Lotfi Belkoura. Delay identification in time-delay systems using variable structure observers. Annual Reviews in Control, 2006, 30 (2), pp.143-158. ⟨10.1016/j.arcontrol.2006.08.001⟩. ⟨inria-00131003⟩
284 Consultations
1747 Téléchargements
