inria-00132200, version 1
Networked control using GPS synchronization
Alexandre Seuret a, 1Fabien Michaut b, 2Jean-Pierre Richard a, 1Thierry Divoux
b, 2
ACC'06, American Control Conference (2006)
Résumé : This work concerns the control, the observation and then, the implementation principles of a remote system (Master and Slave parts) through the Internet network. This communication link introduces variable delays that have to be taken into account in the control-observation loop. The data-sampling effects will also be considered, even in the aperiodic case. The Slave part is considered to be a linear system. But, since its computation power is supposed to be limited, the control complexity (which, here, is an observer-based state feedback) has to stay in the Master part. The global system must ensure speed performance whatever the delay variation. Such a performance is obtained by showing the robust, exponential stability property, which is proven by using adequate Lyapunov-Krasovskii functionals. This makes possible to compute the controller and observer gains by using LMI optimization. The technical solution we propose is based on a GPS system, which guarantees the Master and Slave clocks to be synchronized. Then, the control and measurement packets are sent together with time-stamps that allow for reconstructing a non-symmetric delay information. It means that Master-to-Slave and Slave-to-Master delays are separately reconstructed by the system (and not only the global RTT, round-trip-time). The last part of the paper provides an example where the Slave is a second-order system.
- a – Ecole Centrale de Lille
- b – Université Henri Poincaré - Nancy I
- 1 : Laboratoire d'Automatique, Génie Informatique et Signal (LAGIS)
- CNRS : UMR8146 – Université Lille I - Sciences et technologies – Ecole Centrale de Lille
- 2 : Centre de recherche en automatique de Nancy (CRAN)
- CNRS : UMR7039 – Université Henri Poincaré - Nancy I – Institut National Polytechnique de Lorraine (INPL)
- Domaine : Informatique/Systèmes embarqués
Informatique/Modélisation et simulation
Informatique/Réseaux et télécommunications
Informatique/Robotique
Mathématiques/Systèmes dynamiques
Mathématiques/Optimisation et contrôle
- inria-00132200, version 1
- http://hal.inria.fr/inria-00132200
- oai:hal.inria.fr:inria-00132200
- Contributeur : Jean-Pierre Richard
- Soumis le : Mardi 20 Février 2007, 15:41:03
- Dernière modification le : Mercredi 19 Septembre 2012, 22:20:50
Documents associés
Exporter
