inria-00137865, version 2
Bregman Voronoi Diagrams: Properties, Algorithms and Applications
Jean-Daniel Boissonnat
1Frank Nielsen
2Richard Nock
3
N° RR-6154 (2007)
Résumé : The Voronoi diagram of a finite set of objects is a fundamental geometric structure that subdivides the embedding space into regions, each region consisting of the points that are closer to a given object than to the others. We may define many variants of Voronoi diagrams depending on the class of objects, the distance functions and the embedding space. In this paper, we investigate a framework for defining and building Voronoi diagrams for a broad class of distance functions called Bregman divergences. Bregman divergences include not only the traditional (squared) Euclidean distance but also various divergence measures based on entropic functions. Accordingly, Bregman Voronoi diagrams allow to define information-theoretic Voronoi diagrams in statistical parametric spaces based on the relative entropy of distributions. We define several types of Bregman diagrams, establish correspondences between those diagrams (using the Legendre transformation), and show how to compute them efficiently. We also introduce extensions of these diagrams, e.g. k-order and k-bag Bregman Voronoi diagrams, and introduce Bregman triangulations of a set of points and their connexion with Bregman Voronoi diagrams. We show that these triangulations capture many of the properties of the celebrated Delaunay triangulation. Finally, we give some applications of Bregman Voronoi diagrams which are of interest in the context of computational geometry and machine learning.
- 1 : GEOMETRICA (INRIA Sophia Antipolis / INRIA Futurs)
- INRIA
- 2 : Sony Computer Science Laboratory Paris (SONY CSL-Paris)
- Sony
- 3 : Centre de Recherche en Economie, Gestion, Modélisation et Informatique Appliquée (CEREGMIA)
- Université des Antilles et de la Guyane
- Domaine : Informatique/Géométrie algorithmique
- Mots-clés : Computational Information Geometry – Voronoi diagram – Delaunay triangulation – Bregman divergence – Quantification – Sampling – Clustering
- Référence interne : RR-6154
- Versions disponibles : v1 (23-03-2007) v2 (19-04-2007)
- inria-00137865, version 2
- http://hal.inria.fr/inria-00137865
- oai:hal.inria.fr:inria-00137865
- Contributeur : Jean-Daniel Boissonnat
- Soumis le : Jeudi 19 Avril 2007, 14:32:11
- Dernière modification le : Mercredi 15 Octobre 2008, 14:13:26
Documents associés
Exporter
