Asynchronism Induces Second Order Phase Transitions in Elementary Cellular Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cellular Automata Année : 2008
Nazim A. Fatès
Cellular automata are widely used to model natural or artificial systems. Classically they are run with perfect synchrony, i.e., the local rule is applied to each cell at each time step. A possible modification of the updating scheme consists in applying the rule with a fixed probability, called the synchrony rate. For some particular rules, varying the synchrony rate continuously produces a qualitative change in the behaviour of the cellular automaton. We investigate the nature of this change of behaviour using Monte-Carlo simulations. We show that this phenomenon is a second-order phase transition, which we characterise more specifically as belonging to the directed percolation or to the parity conservation universality classes studied in statistical physics.
Percolation.pdf (252.19 Ko) Télécharger le fichier
inria-00138051 , version 1 (23-03-2007)
inria-00138051 , version 2 (09-01-2008)
inria-00138051 , version 3 (13-02-2008)
Nazim A. Fatès. Asynchronism Induces Second Order Phase Transitions in Elementary Cellular Automata. Journal of Cellular Automata, 2008. ⟨inria-00138051v3⟩
435 Consultations
472 Téléchargements
