Bi-connectivity, k-connectivity and Multipoint Relays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Laurent Viennot
Philippe Jacquet
Multipoint relays were introduced to optimize flooding in ad hoc networks. They are also used to determine a sub-topology containing shortest paths in the OLSR routing protocol. We show that a generalized version of multipoint relays can be used to construct a sub-topology preserving bi-connectivity and more generally $k$-connectivity. Moreover, we show that the multipoint relay structure is intrinsic to any sub-topology with similar properties.
RR-6169.pdf (140.17 Ko) Télécharger le fichier
inria-00142851 , version 1 (23-04-2007)
inria-00142851 , version 2 (24-04-2007)
  • HAL Id : inria-00142851 , version 2
Laurent Viennot, Philippe Jacquet. Bi-connectivity, k-connectivity and Multipoint Relays. [Research Report] RR-6169, INRIA. 2007, pp.9. ⟨inria-00142851v2⟩
189 Consultations
91 Téléchargements
