Asymptotic expansion of the optimal control under logarithmic penalty: worked example and open problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We discuss the problem of expansion of optimal control, state and costate when a logarithmic penalty is applied to constraints. We show that, in a simple case, that the variation of (a regular) junction point, and of the optimal control, state and costate is of order $\eps\log \eps$, where $\eps$ is the penalty parameter.
RR-6170.pdf (241.81 Ko) Télécharger le fichier
inria-00143515 , version 1 (25-04-2007)
inria-00143515 , version 2 (26-04-2007)
  • HAL Id : inria-00143515 , version 2
Felipe Alvarez, J. Frederic Bonnans, Julien Laurent-Varin. Asymptotic expansion of the optimal control under logarithmic penalty: worked example and open problems. [Research Report] RR-6170, INRIA. 2007. ⟨inria-00143515v2⟩
363 Consultations
164 Téléchargements
