inria-00145336, version 1
Robust Multi-Cellular Developmental Design
Alexandre Devert a, 1Nicolas Bredeche b, 1, 2Marc Schoenauer
a, 1
Genetic and Evolutionary Computation COnference (2007) 982-989
Résumé : This paper introduces a continuous model for Multi-cellular Developmental Design. The cells are fixed on a 2D grid and exchange "chemicals" with their neighbors during the growth process. The quantity of chemicals that a cell produces, as well as the differentiation value of the cell in the phenotype, are controlled by a Neural Network (the genotype) that takes as inputs the chemicals produced by the neighboring cells at the previous time step. In the proposed model, the number of iterations of the growth process is not pre-determined, but emerges during evolution: only organisms for which the growth process stabilizes give a phenotype (the stable state), others are declared nonviable. The optimization of the controller is done using the NEAT algorithm, that optimizes both the topology and the weights of the Neural Networks. Though each cell only receives local information from its neighbors, the experimental results of the proposed approach on the 'flags' problems (the phenotype must match a given 2D pattern) are almost as good as those of a direct regression approach using the same model with global information. Moreover, the resulting multi-cellular organisms exhibit almost perfect self-healing characteristics.
- a – INRIA
- b – Université Paris Sud - Paris XI
- 1 : TAO (INRIA Futurs)
- INRIA – CNRS : UMR8623 – Université Paris XI - Paris Sud
- 2 : Laboratoire de Recherche en Informatique (LRI)
- CNRS : UMR8623 – Université Paris XI - Paris Sud
- Domaine : Informatique/Intelligence artificielle
- Mots-clés : Embryogeny
- inria-00145336, version 1
- http://hal.inria.fr/inria-00145336
- oai:hal.inria.fr:inria-00145336
- Contributeur : Marc Schoenauer
- Soumis le : Mercredi 9 Mai 2007, 16:25:21
- Dernière modification le : Mercredi 18 Mars 2009, 14:51:21
Documents associés
Exporter
