Acyclicity of Preferences, Nash Equilibria, and Subgame Perfect Equilibria: a Formal and Constructive Equivalence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In 1953, Kuhn showed that every sequential game has a Nash equilibrium by showing that a procedure, named ``backward induction'' in game theory, yields a Nash equilibrium. It actually yields Nash equilibria that define a proper subclass of Nash equilibria. In 1965, Selten named this proper subclass subgame perfect equilibria. In game theory, payoffs are rewards usually granted at the end of a game. Although traditional game theory mainly focuses on real-valued payoffs that are implicitly ordered by the usual total order over the reals, works of Simon or Blackwell already involved partially ordered payoffs. This paper generalises the notion of sequential game by replacing real-valued payoff functions with abstract atomic objects, called outcomes, and by replacing the usual total order over the reals with arbitrary binary relations over outcomes, called preferences. This introduces a general abstract formalism where Nash equilibrium, subgame perfect equilibrium, and ``backward induction'' can still be defined. This paper proves that the following three propositions are equivalent: 1) Preferences over the outcomes are acyclic. 2) Every sequential game has a Nash equilibrium. 3) Every sequential game has a subgame perfect equilibrium. The result is fully computer-certified using Coq. Beside the additional guarantee of correctness, the activity of formalisation using Coq also helps clearly identify the useful definitions and the main articulations of the proof.
slr_inria_RR2007-18.pdf (315.18 Ko) Télécharger le fichier
inria-00148103 , version 1 (22-05-2007)
  • HAL Id : inria-00148103 , version 1
  • ARXIV : 0705.3316
Stéphane Le Roux. Acyclicity of Preferences, Nash Equilibria, and Subgame Perfect Equilibria: a Formal and Constructive Equivalence. [Research Report] 2007, pp.41. ⟨inria-00148103⟩
133 Consultations
77 Téléchargements
