Improving MPI support for applications on hierarchically distributed resources - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2007
Programming non-embarrassingly parallel scientific computing applications such as those involving the numerical resolution of system of PDEs using mesh based methods for grid computing environments is a complex and important issue. This work contributes to this goal by proposing some MPI extensions to let programmers deal with the hierarchical nature of the grid infrastructure thanks to a tree representation of the processes as well as the corresponding extension of collective and point-to-point operations. It leads in particular to support N M communications with transparent data redistribution.
RT-0336.pdf (105.44 Ko) Télécharger le fichier
inria-00150543 , version 1 (30-05-2007)
inria-00150543 , version 2 (31-05-2007)
  • HAL Id : inria-00150543 , version 2
Stephane Lanteri, Raúl López Lozano, Christian Pérez. Improving MPI support for applications on hierarchically distributed resources. [Technical Report] RT-0336, INRIA. 2007, pp.10. ⟨inria-00150543v2⟩
367 Consultations
383 Téléchargements
