Optimal Sample Patches Selection for Tile-Based Texture Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Weiming Dong
  • Fonction : Auteur
  • PersonId : 840485
Jean-Claude Paul
  • Fonction : Auteur
  • PersonId : 840489
One significant problem in tile-based texture synthesis is the selection of sample patches. The reason is that the tiling process may produce results with poor quality when the sample patches used to fill the tiles can not find good cutting pathes at the merging stage. In this paper, we use Genetic Algorithm to find the best group of sample patches from a considerable number of patch groups. Using tile set gene rated by these optimal sample patches can significantly improve the result quality of the tile-based texture synthesis.
dong-Genetic.pdf (1.7 Mo) Télécharger le fichier
inria-00152395 , version 1 (06-06-2007)
Weiming Dong, Shuangxian Sun, Jean-Claude Paul. Optimal Sample Patches Selection for Tile-Based Texture Synthesis. 9th International CAD/Graphics 2005, Hong Kong University of Science and Technology (HKUST), Dec 2005, Hong Kong, China. pp.503-508, ⟨10.1109/CAD-CG.2005.64⟩. ⟨inria-00152395⟩
172 Consultations
263 Téléchargements
