s'authentifier
version française rss feed
inria-00154571, version 1
Probe Trajectory Interpolation for 3D Reconstruction of Freehand Ultrasound
Pierrick Coupé a1, Pierre Hellier () b1, Xavier Morandi c1, Christian Barillot () d1
Medical Image Analysis (2007)
Résumé : Three-dimensional (3D) Freehand ultrasound uses the acquisition of non parallel B-scans localized in 3D by a tracking system (optic, mechanical or magnetic). Using the positions of the irregularly spaced B-scans, a regular 3D lattice volume can be reconstructed, to which conventional 3D computer vision algorithms (registration and segmentation) can be applied. This paper presents a new 3D reconstruction method which explicitly accounts for the probe trajectory. Experiments were conducted on phantom and intra-operative datasets using various probe motion types and varied slice-to-slice B-scan distances. Results suggest that this technique improves on classical methods at the expense of computational time.
  • Domaine : Informatique/Imagerie médicale
    Informatique/Traitement du signal et de l'image
    Sciences de l'ingénieur/Traitement du signal et de l'image
  • Mots-clés : Image-Guided Neurosurgery – Freehand Ultrasound – 3D reconstruction – Probe Trajectory – Brain imaging
  • inria-00154571, version 1
  • oai:hal.inria.fr:inria-00154571
  • Contributeur :
  • Soumis le : Jeudi 14 Juin 2007, 10:40:52
  • Dernière modification le : Jeudi 14 Juin 2007, 11:34:49
tous les articles de la base du CCSd...
