Scalable Processing of Context Information with COSMOS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Ubiquitous computing environments are characterised by a high number of heterogeneous devices that generate a huge amount of context data. These data are used, for example, to adapt applications to changing execution contexts. However, legacy frameworks fail to process context information in a scalable and efficient manner. In this paper, we propose to organise the classical functionalities of a context manager to introduce a 3-steps cycle of data collection, data interpretation, and situation identification. We propose the COSMOS framework for processing context information in a scalable manner. This framework is based on the concepts of \emph{context node} and \emph{context management policies} translated into software components in software architecture. This paper presents COSMOS and evaluates its efficiency throughout the example of the composition of context information to implement a \emph{caching/off-loading} adaptation situation.
article.pdf (119.43 Ko) Télécharger le fichier
inria-00155045 , version 1 (15-06-2007)
  • HAL Id : inria-00155045 , version 1
Denis Conan, Romain Rouvoy, Lionel Seinturier. Scalable Processing of Context Information with COSMOS. 7th IFIP International Conference on Distributed Applications and Interoperable Systems, 2007, Paphos, Cyprus. pp.210-224. ⟨inria-00155045⟩
219 Consultations
321 Téléchargements
