A Survey of Unix Init Schemes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2007
Yvan Royon
  • Fonction : Auteur
  • PersonId : 840738
Stéphane Frénot
In most modern operating systems, init (as in "initialization") is the program launched by the kernel at boot time. It runs as a daemon and typically has PID 1. Init is responsible for spawning all other processes and scavenging zombies. It is also responsible for reboot and shutdown operations. This document describes existing solutions that implement the init process and/or init scripts in Unix-like systems. These solutions range from the legacy and still-in-use BSD and SystemV schemes, to recent and promising schemes from Ubuntu, Apple, Sun and independent developers. Our goal is to highlight their focus and compare their sets of features.
Mots clés
RT-0338.pdf (294.91 Ko) Télécharger le fichier
inria-00155663 , version 1 (18-06-2007)
inria-00155663 , version 2 (20-06-2007)
  • HAL Id : inria-00155663 , version 2
  • ARXIV : 0706.2748
Yvan Royon, Stéphane Frénot. A Survey of Unix Init Schemes. [Technical Report] RT-0338, INRIA. 2007. ⟨inria-00155663v2⟩
136 Consultations
330 Téléchargements
