Control Camera and Light Source Positions using Image Gradient Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper, we propose an original approach to control camera position and/or lighting conditions in an environment using image gradient information. Our goal is to ensure a good viewing condition and good illumination of an object to perform vision-based task (recognition, tracking, etc.). Within the visual servoing framework, we propose solutions to two different issues: maximizing the brightness of the scene and maximizing the contrast in the image. Solutions are proposed to consider either a static light and a moving camera, eitheror a moving light and a static/moving camera. The proposed method is independent of the structure, color and aspect of the objects. Experimental results on both synthetic and real images are finally presented.
light_v3.pdf (312.26 Ko) Télécharger le fichier
inria-00160949 , version 1 (09-07-2007)
  • HAL Id : inria-00160949 , version 1
Eric Marchand. Control Camera and Light Source Positions using Image Gradient Information. IEEE Int. Conf. on Robotics and Automation, Apr 2007, Roma, Italia, Italy. pp.417-422. ⟨inria-00160949⟩
630 Consultations
240 Téléchargements
