Limit theorems for conditioned multitype Dawson-Watanabe processes and Feller diffusions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Journal of Probability Année : 2008
A multitype Dawson-Watanabe process is conditioned, in subcritical and critical cases, on non-extinction in the remote future. On every finite time interval, its distribution is absolutely continuous with respect to the law of the unconditioned process. A martingale problem characterization is also given. Several results on the long time behavior of the conditioned mass process|the conditioned multitype Feller branching diffusion are then proved. The general case is first considered, where the mutation matrix which models the interaction between the types, is irreducible. Several two-type models with decomposable mutation matrices are analyzed too.
EJP-07-93revised_03_02_08.pdf (360.64 Ko) Télécharger le fichier
inria-00164758 , version 1 (23-07-2007)
inria-00164758 , version 2 (09-12-2008)
  • HAL Id : inria-00164758 , version 2
  • ARXIV : 0707.3504
Nicolas Champagnat, Sylvie Roelly. Limit theorems for conditioned multitype Dawson-Watanabe processes and Feller diffusions. Electronic Journal of Probability, 2008, 13 (25), pp.777-810. ⟨inria-00164758v2⟩
159 Consultations
147 Téléchargements
